Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Andrew (guest)
Guest
Posts: n/a
On my mini one of my back wheels sticks out from the fender about 10mm more than the other even though my camber is identical and my control arms, trailing arms etc are all undamaged. I think this is because of the way the subframe was installed from the factory. Do you know if there is a few mm of play how you align the subframe before you tighten it down? i.e. could I just loosen all the bolts attaching it and shift it over a few mm to even up the back wheels?
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-16-2014, 01:01 PM
Nick at Pelican Parts's Avatar
Sounds like something is bent. I would have the subframe inspected. I do not think there is 10mm of normal adjustment anywhere.
- Nick
