Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Doc (guest)
Guest
Posts: n/a
We have had three heater cores fail in our 2003 Mini S in the past year. All develop leaks. Have replaced with both factory and after market units. Same result. Is there a problem in the system causing these failures or just bad luck wit replacement parts?
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-04-2014, 06:28 PM
Nick at Pelican Parts's Avatar
Where are the units failing (leaking from)? Could be bad luck or electrolysis.
- Nick
