Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mr. FixIt (guest)
Guest
Posts: n/a
I have a 2002 Mini with 5 speed manual transmission. The clutch pedal went flat to the floor. Suspecting the problem to be the master cylinder, I have replaced it. Still no pedal. I have removed everything to get to the slave cylinder. I will be replacing the slave cylinder next. My question is how far should the clutch fork move? Mine does not seem to move much when I manually try to move it. Is this normal?
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-04-2014, 06:28 PM
Nick at Pelican Parts's Avatar
Not much. I would replace the slave and go from there. if the clutch was fine before, it is likely a hydraulic problem.
- Nick
