Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Engine Stalling Part 2
I am updating the post on the problem of my engine stalling on me at traffic lights and stop signs for anybody that is experiencing the same problem. After typing in on google " 2007 Mini Cooper Stalling" I read through a great deal of forums of people experiencing this same dilemma. After reading about Mini's that were stalling and people taking them to there local Mini dealers, only to be told that they couldn't find any problems because no warning lights had shown, which is what was happening to me, and going home for the problem to get worse and then having to go back to there Mini dealer again, it turned out that the solution was simply adding oil.
I went and checked my oil. Checked the dip stick nothing on it, then checked the part where you fill the oil and it was as dry as the Sahara Desert. Shocked was an understatement as I had only in the past few months had a service on the car at our local Mini dealer.
So I gingerly drove the car to get some oil and put it in and thirty miles later the car is running as good as new and no stalling.
I have since found out that with a Mini you should check your oil every 1k miles to avoid this problem from occurring, which I will be doing but every 500 miles......just to be on the safe side.
Hope my update will be of some help before you set of to your local Mini dealer.
Old 04-14-2014, 05:19 PM
914 Geek
The "S" models appear to use more oil than the non-S cars, probably because the burbocharger just plain gets so hot.
MINI's service intervals are quite optimistic, as well. I'm having my oil changed every 6 months, which works out to a bit under 5,000 miles. The original 15,000+ was just ridiculous--and MINI seems to have agreed to some extent, as they changed to 10,0000 miles a year or two ago.
--DD
Old 04-14-2014, 06:46 PM
Thanks for the tip of when to change my oil, will let the Hubby know.
Because of how the car was acting due to the lack of oil, well no oil, do you think I could of done any damage to my engine??? I'm a tad worried now!!
Old 04-14-2014, 08:17 PM
914 Geek
You probably did shorten the engine's useful life. Since the car drives fine again, you didn't do any catastrophic damage. I'd just drive the car, and make sure to check the oil frequently.
--DD
Old 04-15-2014, 07:38 AM
