Guest
Posts: n/a
Is alignment/geometry check required after rear sway bar replacement? Or replacement work will not change wheel alignment?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The wheel alignment should not change when replacing the bar. You should not have to align the vehicle
- Nick |
