Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
deli (guest)
Guest
Posts: n/a
Is alignment/geometry check required after rear sway bar replacement? Or replacement work will not change wheel alignment?
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-02-2014, 03:05 PM
Nick at Pelican Parts's Avatar
The wheel alignment should not change when replacing the bar. You should not have to align the vehicle
- Nick
