Guest
Posts: n/a
Just to clarify, I'm starting to noticed a larger gap between the window and the C and D pillars. As in the weather seal is becoming more exposed and the window has scooted forward. Which adjusters fix this? the ones at the bottom of the door or the sprocket adjusters which requires me to remove the panel?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
If the seal is not worn and in good shape, you can try adjusting the window.
- Nick |
Thread Tools | |
Rate This Thread | |
