Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Aloha808 (guest)
Guest
Posts: n/a
Posting here cause it was the closest in proximity to the issue at hand. Is there a way to unlock the door through the door panel oval via wire?? My passenger door is locked fr inside and outside. Door panel barely pried open. Considering removing the seats. Any help is much appreciated! Other forums are no help on this.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-02-2014, 10:30 AM
Nick at Pelican Parts's Avatar
Yes. With the door panel removed, follow the door lock rod down to the latch. Then move the lever the rod connects to to unlock.
- Nick
