Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mike (guest)
Guest
Posts: n/a
Hi Nick, Is there an aftermarket transmission oil cooler adapter available? I am thinking on something similar to the engine oil cooler adapter photo attached? Also, in other manufacturers vehicles the torque converter usually has oil in it that will not drain out from the transmission oil drain plug. How can the torque converter oil be drained? I would be happy to elaborate on both questions if they are not clear. Happy Independence Day, Mike
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-13-2014, 05:35 AM
Nick at Pelican Parts's Avatar
I am sure there is an aftermarket cooler you can use. There are many universal options use for towing, etc.
A lot of modern converters have no drain. So you are draining what will come and filling it back up. Replacing maybe 2/3s of the fluid. To replace all of the fluid, you would need a flush machine, to pump out the old while pumping in the new at the same rate.
- Nick
