Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Russ (guest)
Guest
Posts: n/a
Hey, Nick- 2002 Mini Base Hatchback 5 speed. 2 weeks ago, the fuel pump would not engage at start-up. I tried it the next day, fuel pump hummed and started fine. Now it is happening again fuel pump won't run only I am unable to "wake up" the pump. I have replaced the relay and checked fuses.
Is there a way to electrically check the 6 pins on the pump plug? Which ones are supposed to be hot when I turn the ignition on? Right now, on the female side of the plug, the black/red wire with yellow dots is hot when I turn on the ignition, but doesn't go dead when I turn it off. Same with black/red wire with white dots. They must time out after a while?
I want to put 12 volts to the pump to check it, but don't know which pins to power. Thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-17-2014, 03:14 PM
Nick at Pelican Parts's Avatar
white/blue is power, brown is ground. I would grab a repair manual to be sure these colors match your vehicle.
Give our parts specialists a call at 1-888-280-7799.
- Nick
