Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
mick (guest)
Guest
Posts: n/a
coolant level is OK,let it idle till the temperature came up the fan never came on.I have check all the fuses,how can I check the fan to see if it needs replacement.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-17-2014, 03:14 PM
Nick at Pelican Parts's Avatar
Check for power and ground to the fan when it is commanded on. If power and ground are present and the fan does not run, it is faulty.
- Nick
