Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Spagtio (guest)
Guest
Posts: n/a
Yes nick, the pedal is stiff with the engine running.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-08-2014, 05:58 AM
Nick at Pelican Parts's Avatar
Confirm the brake booster is getting sufficient vacuum. If so, the calipers may be jammed from the pads. Double check the part numbers you installed. If too big, they may prevent the piston from moving.
- Nick
