Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Jason (guest)
Guest
Posts: n/a
2006 Cooper S stalled while stopped at idle on the highway. Car wouldn't restart for about 10 minutes. Did some searching online and someone with the same problem said their issue was the "main electrical relay was overheating causing the fuel pump to cut off. Replacing the relay solved the problem." Does this sound like a plausible problem/solution? Thank you.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-16-2014, 05:18 AM
Nick at Pelican Parts's Avatar
I see quite a few fuel pumps fail. I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick
