Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Jeff (guest)
Guest
Posts: n/a
My 2006 mini cooper base model is having a weird transmission issue. It seems to not lock out in 6th gear anymore. It will run at 3500rpm at speeds from 45mph to 75mph. Need to know what I may have to replace if anybody knows.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-16-2014, 05:19 AM
Nick at Pelican Parts's Avatar
Hard to say without having some testing performed. This is too critical of a component to take chances on. First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
