Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Elementary Penguin (guest)
Guest
Posts: n/a
I have an 04 S model with a leaky slave cylinder and a pedal that does not come up. More importantly, it went from making a low humming sound to a loud screeching sound. I can also smell something burning when I engage a gear. QUESTION: Are these symptoms indicative of a bad clutch as well as a slave cylinder? Or could the failure of the slave cylinder be the main culprit for the noises?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-29-2014, 10:23 AM
Nick at Pelican Parts's Avatar
The leak ha to remedied, so this is faulty part. The noise and pedal issue could be a faulty clutch pressure plate. You can try to start with repairing the hydraulic issue and seeing if the clutch function returns.
- Nick
