Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Brandon (guest)
Guest
Posts: n/a
My 2002 MCS is overheating, not really sure why but i'm guessing it is the thermostat. Took it to the dealer, said the head gasket was broken, i turned on my car the day before and it did not show any signs of a broken head gasket. There is coolant in the reservoir and no leaks anywhere. any suggestions??
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-10-2014, 09:18 AM
Nick at Pelican Parts's Avatar
I would pressure test the cooling system. If the system will not hold pressure and there are no external leaks the head gasket may be faulty.
- Nick
