Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
romz (guest)
Guest
Posts: n/a
Great write up! I have an r53 mc. It went to the dealership they replaced the fuel pump but know when I drive past half a tank I loose fuel pressure and the car stalls. Wont start up no more fuel pressure has filter changed with pump they cant figure it out I need to any tips will help. Thanks.
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-28-2014, 05:44 PM
Nick at Pelican Parts's Avatar
The siphon jet pump may be faulty or be partially detached. Or an issue with a sealing O-ring or line inside the tank. Ask them to remove what they installed and inspect each component.
- Nick
