Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
martin (guest)
Guest
Posts: n/a
Hi
My daughter has just purchased a 2002 mini 1 1.6 and the gear shift is very stiff although it does select gears. 1st and 5th are pretty bad. Is this a cable issue
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-02-2014, 07:25 AM
Nick at Pelican Parts's Avatar
COuld be. Detach the cables from the trans. If shifting is easy, replace the cables.
- Nick
