Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
l00n3y (guest)
Guest
Posts: n/a
My 06 R53 PSP was giving the symptoms of running even when the ignition is off. Eventually it died and I replaced a new pump. Problem is, I an still getting the new pump running while ignition is of . Any ideas?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-08-2014, 04:36 PM
Nick at Pelican Parts's Avatar
Still running, either battery voltage is too high or the pump is faulty. Check battery voltage when the vehicle is shut down, if it is around 12.6, the pump is faulty.
- Nick
- Nick
Hi Nick. Thanks for your reply.
Battery voltage after vehicle shut down = 12.1V
The pump was replaced with a new OEM pump... Hitting a wall now, and not sure what else to check.
Please help...
Thanks.
Old 11-09-2014, 05:33 PM
