Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Yann (guest)
Guest
Posts: n/a
Just had a new clutch fitted on my 54 plate mcs convertible and now the pedal is firm initially then soft. It engages at the top of the pedal travel where the spring is strongest making it very hard to pull away smoothly. I tend to wheel spin or stall. The garage reckoned they did not need to bleed the assembly when fittin the clutch. Any ideas to smoothen out the pedal travel?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-07-2014, 05:31 PM
Nick at Pelican Parts's Avatar
I would try to bleed the system, it does sound like air is trapped.
- Nick
