Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Reg (guest)
Guest
Posts: n/a
Thanks for the info Nick. But the radiator movement seems to be around the two mounting pins at the top right/left of the radiator. Movement of the radiator is about 1/2 inch or so along those two pins. Is that normal?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-20-2014, 11:58 AM
Nick at Pelican Parts's Avatar
Not likely, the retaining pins should hold it pretty well. 1/2 inch each direction is too much.
- Nick
