Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
race4u (guest)
Guest
Posts: n/a
How long does the 12mm bolt need to be that you screw into the crank for the puller to push on. Trying to prep for my timing chain job. And the 3 6mm bolts you use for the 3 bolt puller how long were those?
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-22-2015, 05:47 AM
Nick at Pelican Parts's Avatar
I don't have bolt lengths for this style of pulley removing. I use a puller that has a long rod that goes into the crankshaft and my puller center bolt.
Your best bet is to remove the center bolt, then get something maybe 20mm longer to push against. If you have a puller, the supplied bolts should work the the M6s. If not, get something about 130mm long and washer to take up any extra space.
- Nick
