Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Tylerfullerton (guest)
Guest
Posts: n/a
After I bleed the slave cylinder it doesn't want to hold the pressure I put on it from the clutch pedal, the second I press it it shoots out the tube connected to the slave cylinder, made sure I put the rubber nipple back on and everything...
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-20-2015, 05:41 AM
Nick at Pelican Parts's Avatar
The line shoots out? The slave or line may be damaged. Inpspect the line groove where the clip sits.
- Nick
