Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Gary (guest)
Guest
Posts: n/a
Hi just had leak blow through coolant reservoir saturating coil
unfortunate placement of both car not turning over
I'm assuming coil is damaged what say yee?
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-14-2015, 07:05 AM
Nick at Pelican Parts's Avatar
I would think so, or just soaked and causing arcing. Try drying it off, then check spark output. Should be able to produce 20kv.
- Nick
