Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
agrdevelop (guest)
Guest
Posts: n/a
2004 Mini Cooper - I have replaced the window regulator assembly which worked well of a couple of weeks. Recently the window stops in the down position and won't come back up. After removing the new regulator assembly the down position is over-driving its lowered position - actually deforming the stop at the base of the track. Is there an adjustment to prevent the over travel?
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-04-2015, 05:55 AM
Nick at Pelican Parts's Avatar
No, there are only adjustments for glass fit. I would assume the motor or regulator is faulty.
- Nick
