Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Norma (guest)
Guest
Posts: n/a
Hi. Excellent article. My 2011 CooperS started going in "limp" mode. My Husband changed the fuel filter first. Didn't seem to fix the problem so he replaced the fuel pump. NOT the one in the tank. Seems to run beautifully now but the problem started again tonight on the way home. Had two bars showing of gas and 57 miles till empty. Towed it home and Husband thought he would put some gas in it for grins and that fixed the problem. Did he bump a float or fuel line in the tank that is now giving a faulty reading of empty and if so, how can we fix the problem? Thanks in advance for your time in answering.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-06-2015, 06:22 AM
Nick at Pelican Parts's Avatar
I would start by checking the fuel sending unit. Maybe the float arm was bent during the repair.
- Nick
