Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Greg (guest)
Guest
Posts: n/a
Hi nick. i have just replaced the cyl head on 2008 mini cooper clubman.
set the valve timing up with the correct tools. but having a problem with the
valvetronic shaft keeps altering advancing up is there any way this has to be set
up. fault codes 2853 2857. Thanks Greg
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-06-2015, 05:01 PM
Nick at Pelican Parts's Avatar
You may have to relearn the motor stops using a MINI scan tool. I would start there.
- Nick
