Guest
Posts: n/a
Hello. Do you have the part # of the hose on the bottom of the expansion tank? When doing an oil change, removing the filter, noticed it was leaking there. It losses coolant over a two week period and there are no other visible leaks nor coolant in the engine.
2008 Mini Cooper S 6 speed. Thank you. __________________ This post was auto-generated based upon a question asked on our tech article page here: |
I’m not the best with part numbers.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need. - Nick |
