Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
EK (guest)
Guest
Posts: n/a
I have a 2010 Mini Cooper S, I was trying to figure out the fill port. The one under the air snorkel is nearly impossible to get to because the T55 bit top is too big get past a piece of metal blocking it. I noticed another torx spot on the back side of the transmission closer to the fire wall. Could that spot be used to fill up the transmission? If not is there a skinnier or longer torx bit head to fit between the metal and the torx spot. Thank You
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Automatic Transmission Fluid Change
Old 11-04-2015, 12:26 PM
Nick at Pelican Parts's Avatar
There are long Torx bits available. I have a set. Give our parts specialists a call: 1-888-280-7799, They will help you find what you need.
- Nick
