Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
XCoach (guest)
Guest
Posts: n/a
Why is it necessary to remove the drive shafts to drop the sub frame? I have my front shocks off to install new ones and was going to drop the frame to install new bushings and ball joints and a larger sway bar...But I don't understand what the drive axles could be interfering with. Please help!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Subframe Removal
Old 11-19-2015, 04:18 AM
Nick at Pelican Parts's Avatar
Because the motor and trans remain attached to the vehicle body, using an engine support. The subframe can't come down with the axles attached.
- Nick
