Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
David (guest)
Guest
Posts: n/a
Hello Pelican parts, I'm very thankful for your technical articles. They are very informative. I was changing the turbo on my 2007 R56 mini and now that I'm completely done, I need to fill the coolant back up. Your article talks about bleeding the air out of the system but it doesn't show the location of the bleeder valve. Can you tell me where it is located? Thanks, David.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Draining Filling Cooling System
Old 11-30-2015, 07:32 AM
Nick at Pelican Parts's Avatar
Some models have a bleeder on the thermostat, at the top. Others do not. You can bleed by filling the system as described in the article.
- Nick
