Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Pat NC (guest)
Guest
Posts: n/a
When replacing batteries on the new cars with all the electronics. I simply put a trickle charger on the terminals prior to removing first the negative then the positive. I then replace the battery with no memory loss. No programming required. Car never knows the battery was replaced.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Battery Replacement and Battery Tender Installation
Old 12-14-2015, 05:54 AM
Nick at Pelican Parts's Avatar
I would not do that. If you have a spike in voltage or A/C voltage from the charger, damage to the electrical system can occur.
- Nick
