Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Byron (guest)
Guest
Posts: n/a
Hi there,wonder if you can help. I recently serviced my 2002 Mini Cooper,changed all fuel filter in the tank also. After service,vehicle started fine and ran well for about 20 km,it then stated to jerk a bit,so I thought I was running low on gas,topped up and no difference,it ran a bit then died,started again and drove,then died again,it is since just cranking. Fuel pump is kicking in,but I'm not sure if the pressure is enough,as I am getting no fuel to the rail. Could my fuel pump be to weak to pump to the front? Don't know what to try now
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Fuel Pump and Filter Replacement
Old 12-14-2015, 05:52 AM
Nick at Pelican Parts's Avatar
Could be an issue with the fuel pump. I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick
