Guest
Posts: n/a
While doing the filter change I somehow dislodged the small sleeve and 3 O-rings that live inside the white plastic top of the filter assembly where the fuel line plugs into. I tried to slide them on the end of the fuel line and insert to no avail. Also pinched one in the process. Does anyone have a part number on these? And if I do get new ones, how do they go back in? Very hard to see in there with everything back together except the fuel line. Thanks in Advance MAN DOWN!
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Fuel Pump and Filter Replacement |
That might be part of the assembly, if it didn't come with the filter.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need. - Nick |
