Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Yellow JCW (guest)
Guest
Posts: n/a
While doing the filter change I somehow dislodged the small sleeve and 3 O-rings that live inside the white plastic top of the filter assembly where the fuel line plugs into. I tried to slide them on the end of the fuel line and insert to no avail. Also pinched one in the process. Does anyone have a part number on these? And if I do get new ones, how do they go back in? Very hard to see in there with everything back together except the fuel line. Thanks in Advance MAN DOWN!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Fuel Pump and Filter Replacement
Old 01-05-2016, 06:30 AM
Nick at Pelican Parts's Avatar
That might be part of the assembly, if it didn't come with the filter.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
