Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
sweepback (guest)
Guest
Posts: n/a
Do I need replace filter?
I think it is metal mesh, So, Is it possible reuse after cleaning?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Automatic Transmission Fluid Change
Old 01-05-2016, 07:38 AM
Nick at Pelican Parts's Avatar
If you remove it, replace it. The seal will be worn and may not seal correctly again.
- Nick
