Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Daforlife (guest)
Guest
Posts: n/a
Do you have a article for transmission fluid change for 2008 mini cooper s automatic engine or R56 mini cooper s Automatic?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Automatic Transmission Fluid Change
Old 01-22-2016, 06:54 AM
Nick at Pelican Parts's Avatar
The article you commented on should cover your vehicle:
http://www.pelicanparts.com/techarticles/MINI/28-TRANS-Automatic_Transmission_Fluid_Change/28-TRANS-Automatic_Transmission_Fluid_Change.htm
if not, I would grab a repair manual. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
- Nick
