Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Kieran (guest)
Guest
Posts: n/a
Hey, i'm struggling to loosen the fill bolt on my '07 Mini R56. I've tried a pipe over the ratchet but it just won't budge. Any suggestions on how to do it as there isn't much room around the bolt. Thanks
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Manual Transmission Oil Change
Old 01-22-2016, 06:55 AM
Nick at Pelican Parts's Avatar
Use a shallow socket and a long breaker bar. When loosening, use a swift motion to shock it.
- Nick
914 Geek
A good penetrating oil, like Kano Labs' Aero Kroyl. WD-40 is not a good penetrating oil.
Tap the plug with a hammer. Don't try to drive it through the transmission case, but let it know it's been hit. That can sometimes break the bonds between the parts, even if you're not loosening it at the time. It can also sometimes help wick the penetrant into the interface between the parts, helping it work better.
If all else fails, heat can help. Just be careful of any plastic or rubber or otherwise heat-sensitive parts in the area!
--DD
Old 01-23-2016, 04:34 PM
