Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
jordan leavitt (guest)
Guest
Posts: n/a
I really like how you said that, "When the brake pedal is pressed, brake fluid is forced out of the brake master cylinder and through the brake lines to each brake caliper." I had no idea that we needed to check our brake fluids for this reason. The other day my breaks went out and it turned out that I was out of brake fluid. What causes my brake fluid to run out?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Brake Pad Sensor Testing
Old 02-06-2016, 12:10 PM
Nick at Pelican Parts's Avatar
You may have a fluid leak.
- Nick
