Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Tremblaym54 (guest)
Guest
Posts: n/a
I have the 002B24 "suction tube" fault on my 2010 R56S and erratic idling. Engine light is on. I clear the fault and it reappears minutes later. Engine runs fine and performance is good but each time I put fuel in the engine cranks but refuse to start until I depress the fuel pedal and crank at least 15 seconds. From what I have read I suspect intake VANOS, do you agree?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - VANOS Solenoid Replacing
Old 02-28-2016, 06:13 AM
Nick at Pelican Parts's Avatar
You will have to check fuel trim to see when and which direction the fuel control is skewed. Once you determine when, you can look at what may be causing it. Vacuum leak, sensor, fuel delivery, etc.
- Nick
