Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Eduardo (guest)
Guest
Posts: n/a
Could I disconnect the clips from inside of the fender by pressing each plastic bolt to get them free from the holes and avoid break each clip? Then I can re use it since the wheel well arch trim will be out with the clips on it.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Front and Rear Wheel Well Arch Trim Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-07-2016, 06:10 AM
Nick at Pelican Parts's Avatar
No. Unfortunately you can't. they need to be replaced every time they are removed.
- Nick
Old 05-07-2016, 06:11 AM
Administrator
Luccia at Pelican Parts's Avatar
Wheel arches and wheel arch clips here if needed: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Exterior Trim - Page 2
Old 05-09-2016, 01:02 PM
