Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Kongfish (guest)
Guest
Posts: n/a
Nick,
Where on a 2007 Mini Cooper S 2-Door hatchback hardtop, is that Coolant Bleeder valve located a Time? I've looked multiple tutorials posted by Pelican but, I yet to see a photo of a 2007 2-Door Hatchback S showing the correct location of that bleeder valve. Do you have a photo of its location.?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Radiator, Thermostat and Hose Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 04-21-2016, 11:10 AM
Nick at Pelican Parts's Avatar
It depends if the thermostat installed has one. Look down past the cylinder head, toward the thermostat, id present, you will see the plastic bolt with an X for a flathead screwdriver. Loosen it.
- Nick
