Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Jeff (guest)
Guest
Posts: n/a
I have a 2010 MCS 6 speed that suddenly doesn't want to shift into 3rd. I can row through the gears fine when stopped with the engine on or off. When moving though, third is difficult or impossible to get into. Sometimes it will slip in with a bit of grinding. Shop says new tranny needed. Does this sound right, or would a fluid change possibly fix this?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 04-29-2016, 07:06 AM
Nick at Pelican Parts's Avatar
Sounds like the trans is worn out to me.
- Nick
