Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
AJ (guest)
Guest
Posts: n/a
I accidentally moved the shift mechanism on the transmission somewhere along the way. How do I make sure is it in the correct position before putting the trans back in the car?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Clutch Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 04-29-2016, 07:03 AM
Nick at Pelican Parts's Avatar
It shouldn't matter, as the cables will attach to the it no matter the potion. For neutral, just move the levers to the center of the travel.
- Nick
