Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mike (guest)
Guest
Posts: n/a
Do you do this adjustment on both wheels at the same time? I just replace the pads and compressed pitons all the way to the dead end. Now my pkg brake lever goes up pretty high. How could it cause that as it was pretty normal before. Thanks for your advice.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Parking Brake Adjustment (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-07-2016, 07:10 AM
Nick at Pelican Parts's Avatar
Yes, make the adjustments on both sides one after the other.
If you removed the rotors, something may be out of adjustment.
- Nick
