Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Kel (guest)
Guest
Posts: n/a
Why can't I get 3rd and 5th gear on my 2003 Mini Cooper on the cable ends under the battery can you adjust them. Many thanks Kel
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 07-13-2016, 05:51 AM
Nick at Pelican Parts's Avatar
Not adjustable, the cables may be worn or you have an internal issue. Try removing the cables and manually shifting the trans into those gears.
- Nick
