Guest
Posts: n/a
R53 automatic transmission just revs up and doesn't move
just bought my son a used 2005 mini cooper s 6 speed automatic and had the transmission replaced in it. The car was running great for about two days and then when he got back up to school the issues began. He stated when he put the car in gear and stepped on the gas pedal that the tach would rev up but wouldn't move forward. He then put the car back into park and shut the car off. He then started the car up again and put the shifter back into Drive and it drove a bit but when he would come to a stop light or stop sign the issue would present itself again. I had the car towed back home which was about 100 miles away and I tried to duplicate the issue, and with great success it did the same thing to me. Now I need to know what you think the issue might be?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
This could be a slip caused by low fluid or low pressure. - Nick |
Thank you for your response and I took it back to my mechanic and we went to a BMW service center and they are saying its the transmission. The good thing about that is that I just had one put in and its under warranty. So it will be getting another tranny next week.
similar issue!
Thanks |
Administrator
Here is some information on the fluid change for your R53 Automatic: MINI Cooper Automatic Transmission Fluid Change (R50/R52/R53/R56/R57 2001-2015) | Pelican Parts DIY Maintenance Article |
The mini scan reader revealed an error code P1682 (DME electronic throttle monitoring level 2/3 idle speed 'A' - calculation fault) I am not sure if this is related to a throttle body or some other related issues. I tested the car today and now it just stuck in this neutral mode even when shift the gear stick to D or R. It won't move but the engine is running and revs fine! Transmission is not engaging at all. Car is not moving ![]() |
Administrator
For P1682, yes it could be related to the throttle body as it's not a transmission code. I've seen MINI's with this code and when replacing the throttle body it fixed the issue. Throttle body here if needed: 2005 Mini Cooper S Hatchback - Intake System - Page 3 |
Thread Tools | |
Rate This Thread | |
