Guest
Posts: n/a
17-12-2-754-231-BOE
Hose to expansion tank to radiator, Im replacing my expansion tank due to the expansion being plastic and not very sturdy i bought the tank and the hose to the radiator, how do you install that? __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Coolant Expansion Tank Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Follow the hose to the other end, disconnect it, then rettach and fill and bleed system.
- Nick |
Administrator
What year and model MINI do you have? You're looking at an article for the first gen MINI, but posted a hose for a second gen MINI.
The coolant expansion tank article you'll want to reference is: MINI Cooper R56 Coolant Expansion Tank Replacement (2007-2011) | Pelican Parts DIY Maintenance Article Hopefully that'll help you with that part better. If you do have a gen 1 MINI you'll want a different part so let me know. |
