Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Rui (guest)
Guest
Posts: n/a
I just replace my rear shocks and I realized you mentioned to tied the top nut with a torque 30nm22ft/lbs but I did it without it and I tied the nut comparing with the way the nut was on the old shock about 1/2 inc down the "piston".My question and I'm afraid it's a dum one is if it is correct or not because if is wrong I have to remove the shocks again from the car and I'm trying to avoid it if I can.I'll appreciated your attention...: thanks.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Rear Shock and Spring Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 10-01-2016, 05:19 PM
Nick at Pelican Parts's Avatar
If you didn't measure torque, I can;t be sure if you got the tightening correct.
- Nick
