Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
ragedmx (guest)
Guest
Posts: n/a
I have r53 SC mini , the water pump conects via water flange to the engine block, but there is other hole to connect the water pump for a non SC version that cap that goes to that hole do you have it available or what part number is?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R53 Water Pump Replacement (2001-2006) | Pelican Parts DIY Maintenance Article
Old 09-22-2016, 05:05 PM
Nick at Pelican Parts's Avatar
The plates are available.
I’m not the best with part numbers.
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
What year is your R53? You're needing the R50 version or the R53 version?
Water pumps - Mini Cooper & Cooper S (R50/R52/R53) - Water Pump, Thermostat & Hoses - Page 1
Water pump flange - Mini Cooper & Cooper S (R50/R52/R53) - Water Pump, Thermostat & Hoses - Page 1
You'll want to make sure to fill out the vehicle info on the right when you click the links above.
Old 09-29-2016, 09:20 AM
